It is currently Fri Jul 25, 2025 9:30 pm
PostPosted: Mon Apr 02, 2007 1:04 pm
They seem to be as common as OM's these days, but here's one I'm working on. Needs two more finish coats of lacquer, but it's getting close...
Sitka Top
Imbuia B&S from Bob C via R Labbe in last year's swap meet
Gotoh tuners from Peter's group buy
Remaining bits and pieces from the usual suspects.
First time working with Imbuia, and it bent and machined much better than I expected given its figure. (The maple bindings were more of a hassle.) Second time working with a double m&t neck and I'm extremely happy with the results. The fretboard stays nice and straight and I love being able to string up the guitar and make any neck adjustments and do the fretjob before there's a drop of finish on the body. Plus as soon as it's buffed out you just re-glue the bridge and bolt on the neck and you're done. Almost instant gratification.
Thanks for looking.
Bob K
Sorry for all the pics, I guess I've been saving them up.
PostPosted: Mon Apr 02, 2007 1:18 pm
Sorry words fail me...
Nice!
PostPosted: Mon Apr 02, 2007 1:22 pm
Bob, thats one fine looking guitar. I really like the stripe in your headstock.
Very Cool. Very well done!!!!!
I am very anxious to see how you like the sound.
Also, I am curious how thick your top was
Andy
PostPosted: Mon Apr 02, 2007 1:37 pm
Wow! That is one hot looking box! I love that Imbuia!
That looks fantastic Bob!
PostPosted: Mon Apr 02, 2007 1:53 pm
I like it! Nice peghead, too.
Mark Swanson
Swanson Guitars
PostPosted: Mon Apr 02, 2007 1:54 pm
Wow, that figure really popped under the finish!
Beautiful work, as well as workmanship.
PostPosted: Mon Apr 02, 2007 1:56 pm
Ahh, alas for the edit button!
I meant to say beautiful wood as well as workmanship. Or was that beautiful woodmanship? Oh, whatever... nice guitar.
PostPosted: Mon Apr 02, 2007 2:09 pm
[QUOTE=Hesh1956] they are getting much more popular at least here on the OLF.[/QUOTE]
It's all Swanson's fault!!!
Your "L" is shaping up nicely, Bob! Smooth work on those top braces.
PostPosted: Mon Apr 02, 2007 2:53 pm
And another WORTHY instrument to praise on this fourm...  This place could publish a monthly MAG with all of the great looking guitars and the construction tips and jigs that people are building.
That is one beautiful guitar, Bob.
PostPosted: Mon Apr 02, 2007 3:47 pm
Nice L-OO Bob! Very nice !
Gorgeous Imbuia,
PostPosted: Mon Apr 02, 2007 9:02 pm
Wow! I really like that Imbuia!
The grain and color are outstanding!
[QUOTE=BobK] Second time working with a double m&t neck and I'm extremely happy with the results.
OK, you've definitely caught my interest!
Does the “Double M&T Neck” involve some kind of jig?
Robert
PostPosted: Mon Apr 02, 2007 9:55 pm
Thanks for the kind words, guys.
Andy, I did the deflection test explained on the "LINT" forum and started with a thickness of .120. I'd be curious to hear what you started with as well. http://www.lint.org/index2.html
Robert, It's pretty simple. Most importantly, you need to add an extra block (i used mahog on the first and ply on this one - ply is more stable) to your heel block. Cut the usual m&t first to fit the rough neck blank. Then I made a simple router template that keys off the truss rod slot to cut the top mortise (neck and body at the same time). Be sure that your mortise is more narrow than your fretboard - and that it stops well before the upper face brace. Cut a tenon to fit the mortise. Remove the neck from the body, glue and level the tenon. Lengthen the truss rod and or cf slots as necessary. Reinstall the neck and drill hole(s) for inserts and screws. At this point you continue as if it were a regular neck. I'll be happy to show you the details at the gathering. Also, do a search for John Mayes' version of this joint. He uses a tenon only glued to the fretboard, but he probably explains the process better than I did.
BobK
PostPosted: Tue Apr 03, 2007 12:03 am
WOW!!!
PostPosted: Tue Apr 03, 2007 2:01 am
[QUOTE=JBreault] WOW!!!
Amen to that!
Go Bob, great looking box.
PostPosted: Tue Apr 03, 2007 4:18 am
Great looking instrument! Isn't that Imbuya fun to work with. As a plus, it smells so good.
PostPosted: Tue Apr 03, 2007 5:19 am
Bob, absolutely stunning wood and workmanship. I too love the headstock.
Ah the smell of Imbuya...it smells a lot like hashish I am told, not that I would know what that smells like
PostPosted: Tue Apr 03, 2007 7:00 am
Thanks BobK,
I'll be looking forward to it!
Its always better to be looking at the something, the same time its being explained to you.
Robert
PostPosted: Tue Apr 03, 2007 8:04 am
She's a beaut, Bob! Great work!
PostPosted: Tue Apr 03, 2007 1:30 pm
Beautiful Guitar!
PostPosted: Tue Apr 03, 2007 1:51 pm
Last Name: Lloyd
I picked up some of that Imbuia a while ago. Your's is simply beautiful. I've been told it has an interesting smell when sanding, both good and bad.
Please let us know how it sounds.
Michael Lloyd
